Fuel tank capacity
TDiddy51
I bought a 2010 Tahoe B RF RE 24 which is imprinted on the fence panel but I can't find that model number in the JD Power specs. Any help with that and other specifics to that model would be great.
tpenfield
Not much on the web that comes up with a Google search. If you want to find out the fuel tank capacity, look for a deck plate that can be accessed, where you can see the top of the fuel tank. There should be a certification label located near the sender fitting, and that label will have the capacity on it.
jimmbo
Spent months looking for fuel tank capacity on my boat, finally gave up...run her dry then fill it...you will know for sure !!
He could pump tank empty(might remove any water as well) while on the trailer, then head to the Gasoline Robber Baron Station. Beats running out of Fuel on the water.
