MistyTazzvon
- Oct 6, 2016
- 18
Hello all, I seem to have a fuel tank issue. Let me explain my setup and what i have tried.
1989 Sunbird Corsica 185 with OMC 3.0 Cobra Sterndrive.
Fuel system is setup in the following configuration:
Fuel tank --> Fuel/Water separator --> Fuel Pump w/filter
Every time i use the onboard fuel tank it and get underway it lasts for about a minute or two then bogs down and dies. It will not start back up from the onboard fuel tank. if i switch to the following configuration:
5 gal gas can --> Fuel/Water separator --> Fuel Pump w/filter
This runs fine all day long any speed.
I have made this switch while on the water so i know the fuel.water separator is not full of water as i do not dump it between switch.
I have taken the air intake line off the onboard tank so i know it is not creating a vacuum
I have completely suctioned the fuel out and replaced it (as best i can with an oil removal canister to suck the fuel out through the hole from the gage sensor)
The only thing i have not done is remove the fuel pickup from the tank as i cannot get it to break lose from the big nut no matter how much power i use.
I don't know what else the issue could be and i hate running off gas cans as they are dangerous and take up precious deck space. Any ideas?
Please note i am pretty sure it is the tank as it seems to run fine by only changing the line from the tank to a gas can.
