I have a 87 gallon Moeller tank in my 2004 Trophy and I'm wondering if it's realistic/possible that the fuel pickup tube could be restricted.
Has anybody ever experienced this with this tank?
Does anybody know if there is a filter/screen at the bottom end of the pickup tube?
I attempted to pull the tube up out of the tank to check it out, but the tube wouldn't come all the way out of the fitting. It slid up, but it felt like something was attached to the bottom end and wouldn't fit out of hole. That fitting (the one with the anti-siphon valve attached to it) goes into another fitting (like a sleeve) that seems like it may be permanently attached to the tank. I hesitate to crank too hard on the outer fitting since I'm told that the boat is built around the tank and the tank itself cannot be removed/replaced if it is damaged. If I break that fitting, I'm screwed.......
Anybody dealt with this?
Thanks,
- Ketchiman
Thanks,
- Ketchiman
