Fuel tank relocate question
OLDFISHER
Greetings , for weight distribution I want to move my 2-6 gal portable fuel tanks to the front of my 20 pontoon fishing boat using the correct fuel line would there be any problems I should consider? I would only have one in use at a time they would be about 16' between the merc. bigfoot 40 hp thanks
roscoe
Nope
but I would place the queezy primer bulb near the tank, as it will push fuel easier than pull it.
GA_Boater
Will 90 pounds really make a difference with a 20' toon?
OLDFISHER
I thought it would be a help, the Bigfoot is a little heavy then theres the batterys
