Boilermaker
- Sep 28, 2003
- 388
I have to replace the old gas tank in my 18ft 1971 WestWind. The tank thats in there now is a steel "VEE" 18gal tank under the bow deck, mounted on top of the floor. I have found a replacment plastic 19 gal VEE tank, but was thinking of putting a larger tank under the floor instead. I could increase my fuel capacity & gain a little storage space where the old tank was.<br /><br />The boat is a modified vee hull with a deep bow section, so I'm pretty sure I could fit a tank in the forward part of the hull. I wanted to rip the flooring up this year and check the stringers, replace the deck wood, and add floatation foam(I don't think it has any). <br />HAS ANYONE done a job like this??? What would I need to do differant for below floor/deck mounting & plumbing?? The fill line now is in front of the windshield on the bow deck>>>so would I need to build something around the fill hose, or just protect it coming thru the deck???<br />ANY IDEAS HERE ??? ALL HELP IS WELCOME???<br />Thanks
