Fuel Tank Sending Sending Unit
Solittle
I suspect that the fuel tank sending unit is not operating properly and must be replaced. Mine is working - - sorta is not close to being accurate. How do I determine which unit to buy so that I get a reasonably correct reading?<br /><br />I have a 115 gallon tank beneath the floor of my 23' CC.
SpinnerBait_Nut
Re: Fuel Tank Sending Sending Unit
SoLittle, I would if you can find the plate on the tank and contact the people that made it[tank] with serial number, model number, etc. That way you would get the right one for your tank.
MGuckin
Guage Troubleshooting <br />I obtained a new sending unit at a local dealer for about $25. <br />Depth of unit was set in the field relevant to the tank depth.<br />Most marine application sending units operate within the same range of resistance.<br />Automotive sending units are normally different.<br />Good Luck
