fuel/water kit
lynnboy021
I need to install a fuel/water filter kit for my 88 omc chevy 5.0 but my question is how do I hook it up??? Like does the fuel line from the tank go to the kit then to the fuel pump then to the carb or does it go like fuel line goes to fuel pump then to the kit then yo the carb???
alldodge
Re: fuel/water kit
Goes from the tank to filter to pump to carb.
lynnboy021
Re: fuel/water kit
Ok cool thanks... I thought it was tank to pump to filter to carb... thanks again
alldodge
Re: fuel/water kit
It goes to the filter first to protect your pump from any crud which may come from the tank
lynnboy021
Re: fuel/water kit
I have a filter so tank to filter to fuel pump to carb.... so should I keep the filter and do tank to fuel filter to fuel/water filter to fuel pump to carb or remove the fuel filter and just keep the fuel/water filter????
alldodge
Re: fuel/water kit
I didn't understand what you said, please clarify what it is you have?
lynnboy021
Re: fuel/water kit
I have one of them cheap glass fuel filter that I added cuz I installed a new fuel pump.... so do I need two filters or remove the glass fuel filter??
alldodge
Re: fuel/water kit
Sorry for taking so long to respond, been pretty busy.
You do not need two filters, the one canister filter is more then efficient, and meets all the requirements
lynnboy021
Re: fuel/water kit
don't need to be sorry.......
ok I got it now thanks so much for your help :) ....
