Fuel Water separator
gobuck
I had a new Merc 383 installed this summer That never reached the recommended max RPM. I put new props on that were 2 inches less in pitch but had the same performance. I was thinking that maybe they put the old fuel filter on that only allowed 25 gph because that was the fuel flow at max throttle. I plan on changing the fuel water separator but wondered if I should go to a 60 gph filter?
Scott06
25 is the rates WOT fuel consumption so it looks like it’s pulling the correct amount of fuel. What rpm were you getting ? and what did the installer say about the issue ? Did you verify the tach is accurate ?
tank1949
I hade Wellcraft, whose tack was 500 rps off. What was wot RPMs before new motor? Does trim in OD and/or tabs work CORRECTLY??? All rings seated by now? What is compression test on cylinders show??? Does ignition have knock sensor and it works????? What is MC ignition ###? Thunderbolt 4 or 5? Are you sure spark is advancing(simple test with timing light) . Is it timed correctly? I'd bet it is in base time and all wires are not attached correctly. My 2 cents??? If my old brain remembers the test correctly, a typical 350 marine Chevy motor that is timed and propped correctly will burn about 10 gals of fuel at 3000 rpms. A stoker will give more power and suck more gas. Check you timing for proper advance!
Ayuh,..... The stock fuel filter is capable of feedin' up to 400 horsepower,.....
Look somewhere else,....
gobuck
Thank you for the responses. I am just pulling straws right now because the boat is dry docked and winterized.
QBhoy
What was in it before ? And is the new 383 a carb or mpi (6.2) ?
gobuck
it had a 1200 hour 260 hp merc 350 vortec. The new motor is a FWC 383 MPI
RPMs were 4100 on the old motor with 22 pitch props, and 4700 on the new motor with 20 pitch props I sent the old props to get reworked to 19 pitch. I know I need to get the RPMs to 5200 so that is what I am working on now. I thought when I got the new motor I would be able to turn the 22 pitch props to the recommended. RPMs. The new motor is suppose to have 350 hp.
Scott06
Your wot rpm range is 4800-5200 so your not far off.
What boat oat and what props - are all these different pitch’s the same prop model? I’m surprised a prop shop would say yeh could move a prop 3” in pitch I would suspect they may not actually be 19”
4700-5200 would need at least 2” lower pitch maybe 3” if you had 4700 with a 20 would think you need 18” or 17 to hit 5200 eapeciallly if it’s a big 4 blade like a revolution 4 that has a lot of bite
NHGuy
You are probably on the right track. I tried going to a bigger pitch (21 Mirage plus) when I put a home built carb 383 in where a 350 mag had been with a 19" Michigan wheel stainless Apollo. The hole shot is fine and the boat runs along well with the 21 but it only makes 4900. When I let it spin with a 19 pitch Mirage plus I see over 5300 rpm.
I think the 19 is going to stay on there. My drive is an Alpha and a 383 is more than an Alpha is supposed to handle. The 19 won't load the gears so much on takeoffs.
QBhoy
I’d think you would naturally need an inch or 2 up in pitch from a 260 5.7 carb...going to a 6.2 mpi of around 320hp. Not sure what’s going on here really. As far as I know the 6.2 mpi should ecu limit itself at around 5150 rpm though. The old carb 5.7 260 should be done at around 4800/4900 rpm
