Fuel/water seperator ??
slamer12
I just installed a fuel / water seperator on my boat i left about 2-3 ft of hose in the transome i kind of loops downs then back up do you think this is too much hose to leave and maybe this can cause air pockets ??
JB
Re: Fuel/water seperator ??
Outboard non-repair.
rabidfish
It probably wont cause air pockets, but...<br /><br />Think of a fuel hose as a drinking straw. The longer the straw, the harder it is to draw a drink...<br /><br />The only "loose" hose should be loose to let the motor turn without kinking the hose.
roscoe
My little 20 year old 15hp Johnson drinks fuel thru a 20' straw.
reel_adventure
I am running mercury outboard (200 hp) with a 100 gallon tank that contains gas/oil mixture. After running 40 gallons of fuel mixture, my oil-water seperator began plugging very quickly. When I dumped out the fuel in a glass jar, I saw a fine particulate (looks like very fine grain sand) but when dry it has waxy feel. Any ideas what this is and would a different filter system extend the time between oil/water seperator changes?
ENSIGN
It's time to clean/replace the tank and replace all your hoses
Mark42
Welcome to iboats. Start your own new thread, because this thread is dedicated to the original posters topic. By starting a new thread, you will get multiple responses directly related to your issue.
Mark42
My MFG has a 40 hp Evinrude on a 14' boat with the tank in the bow. So about 17- 20 feet of hose is needed to reach from the tank to the powerhead. No problems with fuel delivery, and there is a water separating filter in the line, as way as a 3 way valve, and primer bulb. Its best to keep the hose as short as possible, but long runs still work.
