Aqua KNOT Sea
- Jul 13, 2012
- 12
OK so last week I was out and cruizing around and the boat slowed to a stop and stalled. I have had a problem in the past with water in the gas so I emptied the water seperator and she ran fine. All good right. Some new gas and A ton of startron and Dry gass along with running the engin and changing the filter is a easy fix , RIGHT? Next day same problem and the empting of the seporator fixed it again. The Filter is new this season. Now here is where I think I am. I have put the fuel from the filter in a glass container and there is ZERO water in the fuel. The Filter is only half full each time I change it. I have just recently changed the filters in the carb and the fuel pump. Could my problem be as simple as just buying a new fuel eater seperator filter? Or is there some other thing that I am missing. FYI. I usually just screw a empty filter back on and allow the fuel in the carb to prime the system.
Is it possible that I am getting air into the carb and that is causing my stall? The thing that is driving me crazy is that when the boat dies i can get it to start back up but it then stalls out again. It will only run good after I dump the seperator? WHAt do I do
