Finished the repower of my boat with a 5.7 and added a full closed cooling kit. Block and manifolds. I can't believe the difference from the 5.0 and raw water cooling. The temp is much more stable and the motor just seems to run better.
1999 5.7 mercruiser alpha gen2
My question is Can I tee into the line from the power steering cooler to the raw water side of the heat exchanger to add a flush port and flush the heat exchanger and the risers WITHOUT running the motor?
