full throttle issues.. Merc 7.5
MassillonBuckeye
Motor was running fine. Have run about 2 tanks of gas through it(new tank/lines/50:1). Last two times I've had it out, I can't throttle past about half. The power dies. Seems to bog. Doesn't stall. If I back off the throttle then gun it, it usually has all its power until the RPMs catch up. Then I have to back off the throttle. Runs great at lower RPMs. Idle is set a little low and stalls on lowest throttle while IN GEAR. Have cleaned the carbs a couple times, replaced the fuel pump diaphragm last night. Haven't messed with any jets, just the idle screw. New plugs just to see. Same results with old plugs. Float looked fine. I haven't totally torn apart the carb yet. Basically took off, carb cleaner, compressed air and put back together. I'm assuming total carb job?
