fuse block location
jerkoz
am ready to install a fuse block in my 16ft.alum. open bow boat. was going to place the block under the dash, steering wheel side. was going to run 8 ga. pos.&neg. wires to it. planned on a inline fuse close to the battery. does this location seem right? also not sure what amp. fuse to use for the horn and lights?
MH Hawker
Re: fuse block location
You fuse the wire size not the device. 16 = 10 or less, 14 = 15 or less, 12 = 20 or less.
Grandad
Hi jerkoz. So your next question will be what size wire to use, to know what fuse size to use. Your lights should be fine with a #16 AWG wire and 10 amp fuse. The horn could draw significantly more current than the lights, though for only a very short time. You're probably OK with #14 AWG wire and a 15 amp fuse. In regard to the #8 AWG main feed; you may be unnecessarily oversizing this. If you're never going to have more than navigation lights and a horn, #12 AWG should be plenty big enough. If you still plan to use #8, make sure that you have the necessary crimp terminals and an adequately sized crimping tool. Remember too, that an oversized wire is stiff and puts more mechanical stress on a terminal block. - Grandad
jerkoz
the 8 ga. wire I bought is really flexable. thanks for the reply
bonz_d
I've got 8 ga wire running out to the garage to run 30 amp 240v why would you need that size wire for a 16' boat? They don't even use that size wire to run trollong motors.
NYBo
The usual for that purpose is 10 gauge; 8 will be just fine.
