Fuse Block/Panel Photo/Diagram - 1988 Lund Baron 4.3/4bbl/OMC
MMinMN
Hello All,
I am at a loss, I've exhausted google ;-)
I need to get a layout of the fuse panel for this boat, hoping someone can grab a photo of theirs or point me to a diagram of the fuse location/sizes for an 88 lund baron 2100V with the OMC - 4.3l/4BBL(205hp)
NYBo
Welcome to iboats!:welcome:
A lot can happen to a boat in 27 years, so a diagram or photo might be of limited usefulness. However, with a little detective work, you can determine what fuse protects what circuit. If all the electrical devices are working, pull each fuse, one at a time, and see what stops working. If something isn't working, check for a bad fuse using a multimeter or 12V test light. As far as what capacity fuses to use4, remember that the purpose of fuses is to protect the wiring, not the connected devices. For circuits using 16 gauge wire (pretty typical), 10 amp fuses are what to use. You can go smaller for devices that draw lower current (many do), but realize that a short within the device is probably going to damage the device anyway.
