Does my '84, 85hp have a fuse panel? My navigation light is out. I would think it's either a bad bulb, shorted wire, OR bad fuse if it has one. My anchor light works fine. Any thoughts greatly appreciated. Thx Dave
If your anchor lite works in both switch positions the problem is a bulb or a corroded socket. Most older small boats don't have individual fuses for each circuit but instead have a 20 amp fuse in the power line at the battery.
Thank you both...& thats exactly right now thinking about it, I have a 20amp by the battery. Yes, the anchor works in both positions. Yep, I bet it's a corroded socket. Thanks again..
