Fuse Panel Question
Tracker_Pop
My question is: Does anyone have a diagram or know what each fuse controls on an 02' Tracker Pro Team 175 XT?
I know I can test certain ones such as the Nav light, Bilge, Live Well Pump, ect. but there are some I just don't know what they control..
I would also like to get my hands on an owners manual for the boat and the Mercury 40 2 cycle oil injected engine.
Thanks for your help in advance.
Silvertip
Re: Fuse Panel Question
For the Mercury manual go to your local Mercury dealer, Craigs List, E-bay, etc. For your boat, you are probably out of luck. Most manufacturers don't even publish electrical diagrams for their boats. Yes -- they have them, they just don't publish them. If you have a switch you don't know what its for, follow the wire. Or -- turn them on one at a time and see what it does or what doesn't work. There are not that many accessories on that boat so figuring out switches should not be a big deal.
roscoe
01 02 Mercury 40 hp 3 cylinder? motor ?
Any Mercury dealer can get you the owners manual for about $22, or the service manual for about $38.
Or you can get an aftermarket repair manual that will cover the same stuff.
Silvertip
Save the money on the owners manual. They don't tell you much. Spend the money on the factory "Service Manual". It will pay you back many times over if you plan to work on this engine yourself.
