Fused Electronics
woody619
It sounds like I don't need to run fused electronics through fuse block. Do I just connect it directly to same connector coming from breaker where it connects at fuse block? Thanks
seabob4
Re: Fused Electronics
Yes, you can do that. Typically the feed feeding the fuse block bus is protected by a 40A breaker in the stern coming off the battery or battery switch (should be if it isn't). Then each inline fuse will protect each device...
