I've got a bass tracker 17 ft. deep v, 1987 with a Johnson 40 hp. motor, for some reason I have no power to the panel with the toggle switches on them, one switch is for the running lights---one for the bilge---one for the live well-- and one that goes to the fuel gauge. all the fuses are good to the switches. I was mounting and trying to get working a new bow light with a remote spot light on it.it worked one time and then the bulb for the red and green lights would just blink when I tried to turn on the spot light. was going to check the voltage drop at the battery when this was happening but now there is no power to the panel. the only wires are going to the motor from the battery, I'm assuming it reroutes some how back to the panel from the motor, now is there some type of fuse under the motor cover? in so where? and how could it blow without blowing the fuse at the panel..next question, once I get that fixed can't I just eliminate that feed and go directly from the battery to the switch panel? thanks for any help------tom
