gale sea king and buccaneer starters
Docktor
Hello all, I have a GG8835A 25h sea king and would like to replace the starter. I'm looking at a starter for a buccaneer 40h #Z50 19B 58283. Looks like it would fit but would it be compatible? Thanks for any input and if there is anyone I can help with any info on sea king let me know.
F_R
Re: gale sea king and buccaneer starters
Your Buccaneer model number does not make any sense. A typical Buccaneer 40hp model number might be 40DE14B. However, the starter should fit and work, especially if you change the mounting brackets also. The 40hp starter probably is longer and requires a stabilizing bracket at the bottom. Can't tell for sure without a proper model number.
