Hi there
I have a 40hp Gale Sovereign
Model# 40DE15B
I just changed the coils, spark plugs...all that jazz.
I have the motor starting easy and running...
Problem 1:
Start Speed - Motor dies, unless I choke it...then it stays running...have to turn choke off and on to keep it going.
High Speed - Stays running, but sometimes needs to be choked
Low Speed - Stalls out...sometimes keeps going if choked, but most times not.
I adjusted the needle valve as recommended, but not sure if it was done right.
I undo the retaining screw, remove the knob, undo and remove the seat and the needle slides out with the chrome seat and plastic washers.
I turned the chrome seat and washers until it snugged on the needle, then turned it back 1 1/2 turns...replaced the needle, installed the seat, put the knob at 6 o'clock and replaced the retaining screw.
Any ideas?
Model# 40DE15B
Problem 1:
Any ideas?
