Is it ok to use galvanized/ zinc bolts in exhaust manifold?
A aarons 470 Petty Officer 1st Class Joined Aug 29, 2012 Messages 351 Sep 4, 2018 #1 Is it ok to use galvanized/ zinc bolts in exhaust manifold?
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,361 Sep 4, 2018 #2 NO, plain steel bolts work just fine
A aarons 470 Petty Officer 1st Class Joined Aug 29, 2012 Messages 351 Sep 4, 2018 #3 Ok thanks. Why not will they gum up over time? Thanks
Bt Doctur Supreme Mariner Joined Aug 29, 2004 Messages 19,361 Sep 4, 2018 #4 zinc bolts are a lot harder to burn out to remove a manifold not to mention dis-similiar metals
Bondo Moderator Staff member Joined Apr 17, 2002 Messages 71,133 Sep 4, 2018 #5 Ayuh,.... Galvanized bolts are slightly larger diameter, 'n have their own thread sizes, so they won't wanta screw into the heads, anyways,...... Just use plain steel bolts,....
A aarons 470 Petty Officer 1st Class Joined Aug 29, 2012 Messages 351 Sep 4, 2018 #6 Thanks guys appreciate it.
A aarons 470 Petty Officer 1st Class Joined Aug 29, 2012 Messages 351 Sep 5, 2018 #7 I’m not finding the bolt length I need. These are long at 6”, no 5-1/2”s available. so I’m using spacers about 3/8th” you guys see any problems with using spacers?
