Re: GAME CUBE PROBLEM
Several things come to mind...at least what I've had to do to keep my youngest's cube alive.<br /><br />1) Clean the laser lens with a q-tip dipped in alcohol, dirty finger tips tend to hit it with the small CDs<br /><br />2) make sure there isn't anything that's dropped into the unit blocking the movement of the laser head...somehow food particles dont' work well in the movement<br /><br />3) make sure the CD is seated properly on the spindle, somehow part of a label got scrunched against the side of the spindle preventing proper seating<br /><br />4) check the back of the cd to see if it's too scratched to read, surprise, surprise...if the CD is cloudy from being slid across the floor, it won't read.<br /><br />I put his Cube and PS2 on a power strip. Each night the power strip is turned off and so are the power paks. <br /><br />Hope this helps
