Gamefiser (84' Eska) Troubleshooting help
BCavitt
Ok back to my latest nightmare with this outboard. I finally found the leak and got the compression fixed, It was a dry rotted seal, next I wasn't getting spark to the plug, I pulled apart and cleaned the points till they looked new, now I have spark in the wire, I checked the plug and it was horrible, I replaced it with a new one, and yes it is properly gaped to 0.30mm.... Now I tried to start it and it still won't start, I do have the choke pulled, the fuel is mixed properly and the fuel valve open, however when I pull I am not getting it to start. It doesn't even act as though it wants to... Where do I go from here???
JB
Re: Gamefiser (84' Eska) Troubleshooting help
I doubt that the correct gap on that plug is .30mm. Try .030". The point gap should be .020".
Go to the Engine FAQs and do "Outboard won't start".
Good luck. :)
steelespike
Try carefully spraying some fuel mix directly into the carb.
Be sure tha flywheel nut is torqued to 25ft lb.Could shear the key if not tight.
BCavitt
Nope it was the carbs, I overhauled them and it fired straight up! Idle was rough after adjusting however After replacing the fuel lines and fiter it leveed off and is working great...Thanks to eskaman2008 for all the help through messenger and also on the phone... Total cost for new lines, plug, carb stuff, aong with motor 48.86...... However I am still ooking for a manua in pdf format....:)
betzingj
Who is eskaman2008 and where can I find one?
BCavitt
you can find him on yahoo messenger, he also runs a ebay store.... Eskaman2008 is his screen name and he will take you step by step through the trouble shooting to get it working
