Gamefisher 15HP Fuel issues
cushlax34
I have a 1989 Gamefisher 15 model 225 581501. After purchasing a new cdi ignition I finally managed to get spark to both cylinders. I have now run into a fuel issue. It seems as though I am not getting enough fuel. When I prime the motor alot and pull it over at full throttle it tries to start but then quickly runs out of fuel and quits. I cleaned out the carb and it is free of any dirt or defects. I am very close to using this old motor as an anchor!!!
Any help would be appreciated thanks in advance, Eric
jerryjerry05
Re: Gamefisher 15HP Fuel issues
Profile,location?
First clean the carb again and make sure the jets are all clean.
That motor could have one of 3 carbs.Just make sure the jets are clear.
One speck of dirt the size of a pinpoint can clog the jet.
Then rebuild/check the fuel pump.
Ethanol is messing with older hoses.Change all hoses and make sure the gas is good.
