Re: Gamefisher 5.0 Fuel Tank
Thank you. It's an external tank. I guess the only part which is likely proprietary, if at all, is the coupler to attach to the motor. Motor is a made by Eska. The motor fitting has a ball bearing inside. To describe it, the gas hose coupling has a pin in it and perimeter piece which you pull back, attach to the motor male connection. The pin pushes in the motor-side ball-bearing, and you release the perimeter piece which makes the connection lock and the flow open. Now if I only knew the name of that type of connection it would make it easier to say!
Anyway, Chryslers of that era had the same type connection?
