Gamefisher 9.9 Water pump problem
spinreel
My motor has been sitting out in the Arizona sun all summer. I started it up today and found that it isn't pumping cooling water. <br />How do I get to the water pump and remove it so that I can put a new pump in?
scotiany
Re: Gamefisher 9.9 Water pump problem
You're going to have to remove the LU and hopefully just replace the water pump impeller. Not a hard job unless the nuts and bolts are frozen up.
