Re: Garmin 182C Battery Alarm
Adjust one of your data boxes to show voltage, unit voltage should be within approx 0.2 volts of actual system voltage or else you have other issues; this alarm (when set to "on") is generated when voltage sensed by the unit falls below a preset alarm level.<br /><br />Go to the "Alarm" menu and see if it's "ON". If so, is it set to a reasonable voltage (the unit will actually operate down to 10 volts)? If it's not "on", better call Garmin.<br /><br />This alarm has nothing to do with CMOS ...
