I have a Garmin 240 -- it's actually my 2nd one; first one leaked & got water in it, but that's another story... anyway, i have the transom mount transducer w/temp & it's acting wierd.  The transducer is about 3 years old; the Garmin unit is a replacement for the one that leaked and is about 2 years old.  Symptom is temp seems to read fine when i first turn it on, but after 30 minutes or so, it reads absurd temps like 150+ ferenheit when I know the water is in the 50's.  It's not flat offset though, sometimes it'll read 130s, others 140's, I've seen as high as upper 150's & vaguely recall seeing a 170 something once.  Before I replace the transducer, has anyone else seen this & if so, did it turn out to be the transducer, the depth finder or wiring in between?  I have noticed some mild corrosion on a few of the female pins on the transducer cable (the part that connects to the DF.  It appears as a light greenish corrosion around the edges of the holes, but doesn't appear to be inside, so I think it's getting a good connection.
