Garmin Data Transfer ( From Older 7 pin machines)
I can transfer data from Garmin models 182 and models of that generation to a SD card which can then be uploaded into the new garmin gps models. Routes , waypoints and other data that is stored on your older garmin machine can be saved. If you'd like to find out how let me know.
dingbat
You can save the waypoints and track files to computer using the Garmin PC serial interface utility.
From there you have to convert the old map source waypoints file to the latest file format using a old data format to new using the latest Garmin utility. (Base camp?)
Copy converted file to SD and insert in new chart plotter
