seagulljim
- Aug 4, 2017
- 6
My Garmin 451s has been a good little unit and worked fine until recently.
Using a multimeter I have confirmed that a full 12 volts is getting to the unit through the pins. As soon as the unit is plugged in though (not even turned on, just plugged in), the 3 amp fuse blows .This has repeatedly happened and I have already fried quite a few fuses testing it.
The male pins on the unit as well as the female connector on the plug look undamaged and in very good condition.
Would this seem to suggest that the fault solely lies in the unit itself? If so can it be opened up and fixed? Should I be looking further into the electrics setup on the boat?
I am no expert so any troubleshooting tips would be much appreciated!
