gas ball gas tank
FLAMECATCHER
i have a 9.8 mercury gamefisher motor and the motor runs good but when the ball goes soft i stall out unless i keep pumping the ball its a 1998 :rolleyes:
ob
Re: gas ball gas tank
Sounds like fuel restriction on suction side of pump.Check tank pick-up and fuel filter.possibly defective purge bulb
biggwolfe
You might want to take the hose off the between the ball and the tank, and if you have an air hose blow the line out. If you have a filter between the ball and tank try cleaning it out.
