Gas expert wanted
4fishing
Boat has been sitting for a year with full tank (18 gal.) 2 cans of seafoam mixed in, through winter, snow and ice here from Nov-April
Q: drain the gas? thank you
Ayuh,...... Welcome Aboard,..... The gas in the tank will be fine,......
The gas in the carb, pump, lines, 'n filter should be Ok,......
Volume helps gas keep longer,......
In my experience, a teaspoon of gas rots quicker than a gallon of gas, especially the gas of today, vs: the gas of the '60s,.....
Grub54891
Just picked up a 21' Sylvan, was told its been sitting 3.5 years. 3/4 tank in each tank. Took a chance and hit the igniter switch,,, started right up! You should have no issues.
Lowlysubaruguy
Siphon or pump a few cups out into a. Clear container and look at it if its full of water or rust or wrong you should not run it through your carb.
sample the fuel in a clear container
you may be OK, you may have 18 gallons of toxic waste to dispose of.
wahlejim
Master Chief Petty Officer
My only concern would be the excess amount of sea foam in there. That stuff is mostly alcohol and burns hot. I would drain half into 2 5 gallon containers, top it off with fresh high octane to dilute the sea foam. When that tank is empty, repeat.
RE2Master
Always been told: "If it looks like Miller Lite then you should be all right, if it looks like Guinness Stout you need to flush that nasty *** out!"
4fishing
Thanks All! ran great! forgot to mention always run non-oxy in it, Lots of good wisdom from you!
