Gas Gauge Is Pulsing
OkieBill
I run a 92 Charger with a 200 Merc. First time out this spring everything was fine except the gas gauge is pulsing or flickering. It seems to be showing the proper fuel when it hits the high side but it fluctuates back to empty, If you turn the switch off it stays up, does not go to empty. Where would you start?
chuckz
Re: Gas Gauge Is Pulsing
I would take apart all the gas gauge and sender connection, clean them and then re-connect and tighten them.
