79Invader
- Apr 23, 2019
- 45
Hey guys, hope you’re staying safe and healthy. Anyways I went to take my boat out and noticed the gas gauge wasn’t working, was on E (I just filled it up last week when I went out last). I popped the sender out and cleaned the contracts, still same issue. I tested the gauge my shorting the pink sender wire to ground. Gauge pegged all the way to full, actually way past full. Putting a resistor in between the pink wire and ground wire doesn’t change the needle. Neither does an open circuit or when you take the key out. Did I damage my gauge my shorting the wires? Took the sender apart and cleaned it, no change, needle stuck beyond full. Should I just replace my sender? Thanks.
