Re: Gas gauge working intermittenly
Pull the wire terminal spades off the gauge and re-seat them. There should be shiny metal-to-metal contact where the wiring connects to the gauge. A bit of sandpaper will help, but usually just pulling them off and re-seating them a few times will clean them so they make good contact.
After you've cleaned the contacts, if the gauge still doesn't work but it responds to finger taps, the gauge is sticking. That's what gauges do when they get old.
If the problem persists, it's probably the float/sender. It's not difficult at all to replace. Just make absolutely sure you don't have any ignition sources nearby when you swap it, and make sure it's properly sealed when you're done.
