Re: gas gauge
Describe the symptoms in more detail please. Does the needle sway with the sway of the boat? Does it read empty all the time? <br /><br />The sender should have two wires, a ground and a sender wire. Make sure the ground wire is making good contact. Ground out the sender wire - the guage should go to full, if it does, you have a faulty sender. If it doesn't, you have a faulty gauge or sender wire.<br /><br />Aldo
