Gas Help?
magnum 76
I have a 70hp evinrude is it ok to run 91 octane gas or should i run 87 octane? <br /><br />thanks
Hooty
Re: Gas Help?
87 'll work just fine unless you'd rather spend the extra coin. ;) <br /><br />c/6<br /><br />Hooty
EZ RUDDER
Re: Gas Help?
I was under the impression that the higher octane fuels burn cleaner and produce less carbon build up?
JB
Re: Gas Help?
You had the wrong impression, EZR.
