gas in oil tank
haywire
I have a 2000 35hp johnson,we found gas mixed with the oil in the tank, is this supposed to happen?
the engine blew up for no apparent reason it was running super and started running rough now we have to rebuild or get powerhead its it recommended to premix for this motor ,and disable the oil mixer.
engine looks like it was starved for oil/cooling in #1 cylinder only, no buzzers went off. metal in cylinder going to pull apart today
Chris1956
Re: gas in oil tank
No the oil should never get to the oil tank.
I could not find a listing for your exact motor, so I looked at a 40HP from 2000.
Inspect the fuel pump for proper operaton. They have a real good reputation for reliability. If the pump is bad, it is a $400 item. A bad pump would starv all cylinders equally of oil. Maybe you have a dirty carb on #1
tashasdaddy
Re: gas in oil tank
oil in oil tank, i would say it was lubing the motor with gasoline. hole in diaphram.
haywire
Re: gas in oil tank
pump appears okay but didnt tear completly down it is a mixer valve i dont have vro just seems strange, ya lubing with gas
