I found out that their is gas in the oil not water, I can smell it, I replaced the gasket on my carb., now their is gas in the oil, is that from not putting gasket sealer on the gasket when I replaced the carb? What would be the right way to clean this out of my engine? Would this do any damage to the engine because their is gas in the oil? Shoud I flush out the engine before I add new oil and change the oil filter? Thanks in advance!
Just Change the Oil,Filter,+ Readjust the Float Level in the Carb.......<br /><br />If you're talking about the Gasket Under the Carb,<br />A Leak here would be an Intake Vacuum Leak..........<br />Not a Gas in the Base Leak..........
