Gas leak when motor is trimmed up?
BigJeff
I have noticed that when I trim my motor up completly or even most of the way some gas seems to leak out of the motor onto the rear splash pan, I have not found any bad hoses so I am imagining it is something in the carbs, I did replace a missing gasket on one last year but this problem still continues. And as I mentioned I do not have any issues when the motor is trimmed down.
96 Merc 135hp
Parts Listing:
http://www.crowleymarine.com/mercury-outboard/1678.cfm
Service Manual:
http://1manual.com/Mercury manuals...52r3/cover.pdf
Chris1956
Re: Gas leak when motor is trimmed up?
It is normal for some fuel to leak out of a carb bowl when you tilt the motor, past the trim zone. In your case it gets trapped in the airbox until you trim down and then it runs into the cowling, right?
BigJeff
Not sure how much is getting trapped in the cowling I will try to watch later tonight when I run it and then trim it up. It usually drips out into the back transon area of the boat. and not much but may be an .5 oz or so. It would make sense to me that if the carbs has gas in them then that would leak out if I trim up all the way but I don't remember my previous merc doing it.
SingleShot
My 2003 125 has done this for years. It seeps out as posted above. In the garage I just leave it trimmed down.
diehardmason
I have a 1996 125 and it does the same thing. Was wondering if that was normal. Maybe its common to the similar sized motors?
bajaunderground
I have a 200 and it does the same thing when tilted. It could be normal or it could be a stuck float or little pieces of whatever in the jets??? When was the last carb rebuild? I rebuilt mine last summer and most of the leaking stopped.
Texasmark
Let's take a bottle of windshield washer fluid; the blue stuff. Use it up and take that bottle and use it for water to dilute your fire ant spray. If you turn the bottle upside down, with water in it, it will gurgle out at the rate that the air is replaced for the fluid that left.
Carbs have a venturi jet in the carb air intake whereby the "wind" going by sucks fuel up from the carb bowl. You have a carb full of fuel, a venturi jet below the level of the fuel in the carb and wala. You have leakage. Simple solution. Don't leave your engine tilted up longer than is necessary to support your fun in the sun.
HTH,
Mark
SgtDeadeye
BigJeff,
I am by NO means any type of expert, but what I was TOLD was that some gas leaking is normal, but many times its because the float level of the carbs is set too high? Not sure when you last checked those, but it might be worth a look.
Happy Boating
96 Merc 135hp
Parts Listing:
Service Manual:
BigJeff
I will have to look at the level to see if it needs to be adjusted. Sounds like a carb rebuild would be good for the old girl. Took her out yesterday and she ran great. Andrea the fish where biting.
