Gas Leak
Status
Not open for further replies.
rdavis0212
Thank you in advance
I have a 2008 Tahoe Q6 4.3 with a Gas Leak I filled the tank and when i arrived at storage 4 miles away strong odor of gas. I found gas running out drain and the bilge puddled in the engine compartment all hoses and seal @ sending unit are good so have to assume it is the tank!
Anyone else have this issue and if so how do you replace the tank without Cutting the boat in half!? The only access to the tank is approx 8 inches x 30 inches, balance of 45 gallon tank is fiber glassed/molded into the boat!
From everything i can see it is on the bottom or rear of the tank and coming out under it!
Any help would be greatly appreciated
Thanks again
Russell
tpenfield
You posted this on another forum (right?)
You probably got a good indication from the input you have gotten over there so far. Feel free to post a few pictures to aid in further input.
southkogs
Let's stay with one topic. I've left the other one open, but I'll close this one.
Status
