So I could smell gas in my garage tonight. Upon inspection I realized gas is leaking out of the back of the boat from this "vent" looking deal. It is pictured below as a close up and it is in the center of the larger picture. It is a round "vent" or something located on the back of the boat. It almost appears to be an ignition switch (like you could insert a key) which it obviously isnt and the slot isnt open. (That is just the closest thing I could relate it to. I filled the boat up to the top with gas before winter as part of the winterizing process. The tongue of the trailer was sitting up on a cinder block so it was up higher then normal. But I havent moved it all winter and it just started leaking fuel out of this. What is it and why is it all of a sudden now leaking? Thanks.
