Gas line for kicker motor
drice379
I hav a 90 hp Yamaha and a 5 hp Nissan kicker motor. Can the gas line used for the big motor also be used for the kicker or does it need another end?
pvanv
Re: Gas line for kicker motor
If they are both 4-strokes, just Tee-in a Tohatsu/Nissan primer bulb/fuel hose for the 5 hp motor. But be sure that you use the primer bulb, for its check valves, so that one motor doesn't suck air through the other's fuel system.
drice379
Actually the 90hp yamaha is a two stroke, what do I do in that case?
drice379
The 90 is oil injected though if that is the concern.
