Your Force requires a 50-1 ratio. The easiest way of measuring is to add one pint of TCW-3 oil to six gallons of fuel. This actually will give you a 48-1 mix but the ease of mixing far outweighs the slightly extra cost of excess oil. The Force is definitely an old school engine and very tolerant of excess oil. Thus, when in doubt such as adding oil to a partial tank, if you can not get an accurate fuel measurement err on the rich side.
Your Force also uses surface gap plugs. these tend to easily foul with low speed running and trolling. Carry an extra set of plugs and a plug wrench. At the first sign of low speed stalling or hard starting, change the plugs. The old plugs can be cleaned with a green Skotchbrite pad. They are re-useable any number of times. I have plugs over 15 years old with hundreds of running hours and they still function perfectly.
