Re: Gas Pouring Out
Yes, mercury and mariner side bowl carbs are especially touchy about being level. Tilt them and gas will undoubtedly drain out of them. Most even have a baffle under the cowl to drain that fuel out of the leg. As for running the motor dry, I usually disconnect the fuel line right before i load on the trailer. I have plenty of fuel to load up the boat and then i let it run until the first stall. There is still some residual fuel in the bowls but not as much.
In regards to storing the motor in the down position. Yes - I get home, park the boat, prop up the bow, remove the transom saver, and lower the motor. Fortunately, I store my boat on a raised patio, so I can get the motor pretty much all the way down without digging it into the ground. If stored tilted upward, water will not properly drain, and with outside winter storage, that could lead to a cracked gearcase.
