gas ratio for 4r71d
Daviet
Re: gas ratio for 4r71d
4R71D = 1971
That engine does not have roller bearings on the crank and rod, I would use 24:1 ratio fuel mixture.
jimmbo
16:1 is probably what was speced for it
Rick.
Actually the Johnson/Evinrude book says 50/1 for the mix. I have been gradually persuaded re:the lack of roller bearings and now I'm using 25/1 like others have suggested. They are fine little motors and run all day on a tank of fuel. I use a 71 Evinrude as my kicker. Best of luck. Rick.
JB
Use 24:1, which is the current spec for sleeve bearing outboards.
A really great little outboard. . .best ever made.
