gas shooting from carb volvo aq131a
geo216
Went to start boat after putting in new plugs wires cap and rotor when turned key gas was shooting out of the carb.... I was told that it could be out of time or the head gasket could be bad can anyone help me as to where I should start
Don S
Re: gas shooting from carb volvo aq131a
Check your firing order. If it ran before you put the new wires on, then you may have the wires in the wrong locations.
geo216
Wires are in correct order I went off the book to install them. I'm just lost as to what it could be
Maclin
Did you replace the wires one at a time? Or take them all off then replace? A previous distributor-removing episode may have had someone have to put the wires on at a different starting post than the book shows.
Is the distributor loose? Meaning, did it turn any when you removed the cap and replaced it?
Did the new parts look like the old parts?
geo216
i replaced everything with new parts the were bought by me and yes they all looked new. As to the wires I went off what the book says as to where they go thats why I'm lost here.
Maclin
If the engine was running OK before you replaced those parts then this almost has to be the plug wire firing order. It could be that the #1 plug position on the distributor cap on your engine is not where it shows in the book for some reason. Are you sure the #1 plug wire is in the same location on the distributor cap now as the one you removed?
If you are not sure the #1 wire is in the same spot as before, AND you are certain the wires are connected to the distributor in the correct firing order now then try shifting them around the cap one position at a time, keeping them in the same order, as in move each wire one position to the left, try starting the engine, then shift them again if it is worse or the same. Just take note of where they are now before you try this. Be sure to have a water supply connected.
Maclin
On this I meant did the new parts match the old parts in shape, size, etc.
geo216
I tried shifting the cables one spot at a time on the cap and still wouldn't start I'm getting fuel and spark the two just aren't meeting and igniting.
Parts all look the same as the old ones and are same size.
