MountainMan57
- May 16, 2015
- 18
I took off the whole set of 3 carbs, cleaned them up, all appeared in good shape, put everything back in place. When I was pumping the squeeze bulb, I heard something squish which wasn't air coming out of the carb...it was gas. I heard it again and didn't get a great firm bulb. I didn't see gas so I started the motor. It took a bit, but finally got it up and going and while it was running (weak, a little rough) I looked behind the air handler and gas is pumping out both sides of the carb. I have taken pics of each side and circled the hole gas was coming from. I am NOT anything close to a mechanic. What the heck? I did have a can of air there, so I shot a little shot in the top side forward hole and gas shot out of the low side hole closer to the choke 2 feet! So what is going on. It might be I have finally narrowed down where my bigger problem has been with this engine but I don't know what I narrowed it down to!
