gas tank capacity, hydrasport 1800 CC?
Re: gas tank capacity, hydrasport 1800 CC?
Ayuh,.... Measure it,.... then figure 7 gallons per cubic foot...
robert graham
Are you thinking capacity of your present tank or buying a new tank?
cabsav
i was hoping i could get definite answer without dismantling boat to measure tank, i need to add oil before i can take boat to water. thanks
robert graham
Get a 5 gallon jerry can, add the correct amount of gas and oil, add that to your tank, repeat that until your tank is full. You probably have about a 20 or 30 gallon tank and you will learn through use about how much it holds without having to tear up your deck. Good Luck!
cabsav
i appreciate the replies i have gotten so far, still do not know how much untreated gas is in her. the manufacturer does not have info going back to 1986.
JoLin
Do you have an access hatch over the tank sending unit/fill nipple? Pull it and look for a tag on the tank. Should have tank manufacturer, model and capacity listed.
My .02
