gas tank cleaning
delsol
i have a 30 gal gas tank. any good idea's on how to clean it.
Scout Sport Fish
Re: gas tank cleaning
My thoughts exactly. There shouldn't be much to clean inside the tank unless is a disel tank thats been sitting for a while. Dont worry about it. Just keep the filters new every year.
delsol
engines being put in at shop boat sat 5-10 years or so. thats why i wanted to pull tank and clean it the last one i had a leak in it. i could not find a tank the right size. si i filled it with water and a guy charged me 100.00 to weld a nice patch on the alm.
bob
p/s what would you guys do with this 30gal tank
delsol
bump anyone want to tackle this question
delsol
must i remove the tank????
thanks bob
studlymandingo
Is this the tank that was welded?
I would imagine that you would need to pull it in order to properly clean and then dump the cleaner out.​
Chris1956
Bob, I usually tilt the trailer tongue up and siphon out the lowest part of the tank to get the water out of the tank. If you need further cleaning, you likely will need to pull the tank and toss in some washers, bolts nuts, etc, and swish them around. Now you can drain the dirt out of the tank via the fuel gauge sender.
